Re: Super A
Posted by Haas on April 19, 2008 at 17:57:52 from (12.65.36.232):
In Reply to: Super A posted by roger cox on April 19, 2008 at 15:02:32:
I had that happen twice for two different reasons. First reason, wires on distributor connected in clockwise direction, but the distributor rotation was counterclockwise. This of course puts things out of time and the engine tried to start on only one or two cylinders. Second reason. Timing 180 degrees out due to magneto which has only two lobes on breaker cam and 2 to 1 gears to time the points to the 4 wire distributor cap. Both these situations will cause oil to be blown back out the air cleaner in my experience.
