Posted by r4etired on April 19, 2008 at 18:08:37 from (166.226.217.189):
In Reply to: H governor posted by JThomas on April 19, 2008 at 18:00:27:
When you installed the carb are you sure you installed the finger on the gov shaft in the slot in the butterfly shaft. There is also an idle stop in the govenor,shoud be the bottom screw, also there is an idle adjusting screw where the gov shaft connects to the carb
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
