IH 2444 novice rebuilder
Posted by Bill Hunt on April 19, 2008 at 22:01:16 from (98.227.82.183):
Looking for some help with this tractor I recently bought. I am in the process of cleaning the fuel system which had totally turned to muck (tractor sat for 5+ years)
Hydraulic fluid, Should it be changed? How to tell if it is low, etc. Also, is there anything else I should check before I fire it up. Tractor has a IH 2000 loader on front. Thanks
