Re: farmall h engine rebuild
Posted by ihc49 on April 20, 2008 at 12:47:28 from (216.123.197.147):
In Reply to: farmall h engine rebuild posted by Bill Bowen on April 20, 2008 at 12:25:03:
are you sure you got the right studs back? all sixteen are the same length, about 5" above the block.
