Re: Farmall H engine question...opinions needed.
Posted by kfox on April 20, 2008 at 15:15:26 from (63.18.191.168):
In Reply to: Re: Farmall H engine question...opinions needed. posted by Jesse on April 20, 2008 at 13:39:34:
That cover for the valve lifters/pushrods has copper washers under the bolt heads. That may be the only problem. Most I have seen have never been replaced since the tractor left the factory. There is also a breather filter for the crankcase under the pipe attached to the cover. Most of these are plugged solid. A "Brawney" stainless steel scratch pad makes a good replacement filter.
ken
