Re: Front Tires on 560d
Posted by migraine on April 20, 2008 at 15:38:24 from (67.182.151.248):
In Reply to: Front Tires on 560d posted by scotty-mn on April 20, 2008 at 13:44:36:
We run 7.50-16 and this seems to set them level with 16.9-38 on rear. If you have 15.5-38 on rear then 6.50-16 fronts seem to run at level. Migraine
