Re: 584 Air in brake lines
Posted by JimB2 on April 20, 2008 at 16:17:59 from (99.241.179.24):
In Reply to: 584 Air in brake lines posted by dzwoodcutter on April 20, 2008 at 11:44:24:
Hi Cutter, chech the simple things first like:
1)Level of Hytran fluid, if loader can over fill by 5 gals.
2)Hydraulic leaks.
3)Clean hydraulic filter.
4) Contanmination of Hytran fluid with other oils from remote hydraulic implements. This can cause foaming and air bubbles in the hydraulic system.
5)Never pump the brakes if the engine is not running.
The problem with these brakes is that the hydraulic feed is a dead end circuit fed by the return line from the oil cooler in front of the rad, so any leakage in the lines or seals causes air bubbles.
JimB
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
