It does matter which side: It goes on the side of the amp gauge not connected to the battery. The generator terminals should be all ignored. they are all either direct ground, or ground through the resistor (usually a flat piece of flaky mica, or asbestos) this stuff is no longer needed due to the alt. The switch positions are, from full CCW: Low Charge (now not used and therefore OFF) High Charge (now not used and thus OFF as above) Dim front Lights connected through the resistor, and rear light on High All lights full on rear and front. Stay away from the grounded terminals on the switch, they are cutout relay style generator use only. JimN
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
