Posted by ihc49 on April 20, 2008 at 20:03:19 from (216.123.197.160):
In Reply to: MD 9 posted by Red Bob on April 20, 2008 at 18:51:07:
MD9??? no such thing. must be WD9 or TD9.but anyhow it seems you want to bleed the fuel system.just bleed the primary filter,and secondary filter.if you need to, loosen injector lines at injectors to bleed pump and lines.the flip cap on top is for engine oil.the pump holds about 2 cups of oil.the 1/8 plug on btm is the oil drain.you change this oil at same time as engine oil, or sooner as the transfer pump seals usually leak diesel in here.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
