Re: 300 ult cluch
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Mark on March 08, 2000 at 18:38:11 from (209.176.193.117):
In Reply to: 300 ult cluch posted by curtis perry on March 07, 2000 at 13:13:24:
Curtis:
I have a 300 Utility with the same symptoms. I pulled the clutch inspection plate off the bottom of the tractor and two pieces of clutch fell out with it!
The clutch had seized from sitting around too long, so when I stepped on the pedal it broke off one of the clutch bosses and dropped a spring. Now the clutch basically won't disengage, which makes it impossible to shift without grinding gears when the engine is running.
Make sure that if you store your tractor for six months or longer, you block the clutch in the disengaged position per the operator's manual.
To answer your question, I don't know of a way to fix the engine clutch without splitting the tractor.
Mark
Post A Followup
: Re: Re: 300 ult cluch
Today's Featured Article - Product Review: Kreem Brand Fuel Tank Liner - by Staff. This condition has occurred on a few machines that we have had and fortunately we were able to borrow the technique used at the local motorcycle shop. The product that we have used is called Kreem thouh there are others on the market, this one was recommended and available. This particular product is sold in three parts, a bottle of etch, dryer, and sealer. We were fortunate enough to start the process with stern warnings from those that had used this type of product before. The horror ... [Read Article]
