Re: Engine will not shuff off
Posted by ScottyHOMEy on April 21, 2008 at 08:36:34 from (71.241.213.254):
In Reply to: Engine will not shuff off posted by BrianGNC on April 21, 2008 at 08:28:16:
Could be that a surge that cooked your VR also did some damage in the switch, or vise versa. Have you got a multimeter to test the switch out to make sure it's functioning? (If not a multimeter, how about a test light? With the switch disconnected from the tractor, run a jumper from the ground of your battery to one terminal, and a test light from the other terminal back to the hot on your battery.) I'd start there.
