Re: FARMALL 560
Posted by Armand Tatro on April 21, 2008 at 16:31:05 from (98.227.135.78):
In Reply to: FARMALL 560 posted by Keith Bracken on April 21, 2008 at 16:06:23:
Do you have an 0wners manual or an I&T manual? When was the last time the T A and the clutch linkages were adjusted? This must be done on both linkages and BY THE BOOK!!!! Try these adjustments before you do anything else!!! Armand
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
