Posted by Haas on April 21, 2008 at 18:32:42 from (12.65.6.132):
In Reply to: MD 9 posted by Red Bob on April 20, 2008 at 18:51:07:
The flip up cap is for lube oil, the same as you use in the engine crankcase. The petcock on the side of the pump is the oil level. Lower plug is to drain the old oil when you change the oil. Nothing to bleed on the injection pump. You bleed at the filters and then by running in gas mode and advancing the diesel speed control lever and hope for white smoke which will indicate diesel is getting to the injectors. If injector lines have been drained due to overhaul, etc, then you may have to loosen connections at the injectors while running in gas mode to get all the air out.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
