Re: I know nothing...help please
Posted by GeneMO on April 21, 2008 at 19:10:01 from (216.74.196.145):
In Reply to: I know nothing...help please posted by Scott Olsen on April 21, 2008 at 18:30:55:
Remember, it is POSITIVE ground! Or at least it should be. Clean the bat. cable ends first, then work your way to the starter, cleaning until you find the culprit. As someone else mentioned, the starter often locks on those ole tractors.
You can unbolt the starter and wiggle it a little, or rock it by putting in 5th and rocking the rear wheels a little. Make sure switch is off and no one in the way, just in case.
Gene
