Re: moving a dead td15b
Posted by Janicholson on April 21, 2008 at 19:44:15 from (66.173.50.166):
In Reply to: moving a dead td15b posted by SouthWestBill on April 21, 2008 at 17:51:14:
It can be done.
Pull with chains across the tops of the tracks pulling so the top of each track is pulled forward. You might need a spreader to keep the chains on top, and straight ahead.
Use a rear load lowboy, or a two piece removable front unit, so it can go on straight.
It will be an event. JimN
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
