Re: I know nothing...help please
Posted by gene bender on April 22, 2008 at 04:14:13 from (67.55.226.69):
In Reply to: I know nothing...help please posted by Scott Olsen on April 21, 2008 at 18:30:55:
Your starter is locked up just loosen the two bolts that hold it in place and the cable going to it. Look at the end where the bendix is and it probably needs a little cleaning and lube acouple squirts of wd-40 will be ok. Now if the cables are clean on both ends it should turn over easy. Train those kids not to play on a tractor. You dont let them set behind the wheel of your car and turn switches.
