Re: 504 loses power after an hour
Posted by onefarmer on April 22, 2008 at 05:43:27 from (216.93.96.40):
In Reply to: 504 loses power after an hour posted by David V on April 22, 2008 at 04:24:33:
Might be starving for fuel like Hal said. Since it does it after about an hour, I'd suspect a plugged tank vent. Run it wait for it to act up and remove the fuel cap. If it helps the vent is plugged.
