Matt Compton, MD Starting
Posted by Peculiar Farmer on April 22, 2008 at 06:43:11 from (64.19.38.166):
Went through the entire I&T manual adjusting starting mechanism. Found everything out of whack but also found #2 starting valve may not be closing all the way, will pull the plug later to verify. It did start a lot easier after making all adjustments. Checking clearance between starting valve cover and lever is not easy. Going to pull a plow with it this weekend to see if that loosens things up.
