It could be the coil getting hot and breaking down. If you let it sit about a minute or two does it have full power or is the motor still struggling. Low fuel flow will let the carb catch up after sitting a couple of minutes as the gas trickles in. A hot coil is most likely going to show the same symptons until it cools off, like after and hour or so.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
