Re: 700 Plow
Posted by Chuck46 on April 22, 2008 at 08:47:04 from (64.136.27.230):
In Reply to: Re: 700 Plow posted by Hugh MacKay on April 22, 2008 at 06:45:47:
Hugh, The 700 was both a pull type and semi-mounted in 4,5, and 6 bottoms with either in furrow or on land hitchs begining in the fall of 68.The 68 models had red springs for the automatic resets. Mine is a 5-16 in furrow semi-mounted bought new in June of 69. The 710 replaced the 700 in 4, 5, and 6 bottom sizes and the 700 was then made only in the 7 through 10 bottoms. Have a good day, Chuck
