Re: I know nothing...help please
Posted by trucker40 on April 22, 2008 at 09:39:18 from (69.149.15.128):
In Reply to: I know nothing...help please posted by Scott Olsen on April 21, 2008 at 18:30:55:
Starter might be hung.You can put it in high gear and rock it back and forth and it might come out,otherwise you have to loosen up the 2 bolts that hold it on and it should come loose.Old tractors like that do that a lot.Even old cars and trucks would do that,most of them had a standard transmission and the way to get the starter loose is put it in high gear and rock it,better have the switch off just in case so it doesnt start up and run over you.
If its not that it could be the battery cables need to be cleaned,or a bad connection somewhere,most likely in the battery cables,or from the switch to the starter.
