Just keep in mind the stock H/Mlower bolster is configured to provide a small positive caster (tire patch is behind the pivot shaft axis). The wedge correctly installed reduces - but does eliminate - this positive caster.
Nor does the wedge change the angle enough to result in negative caster (tire patch ahead of the pivot shaft axist). Negative caster gives unstable steering action ("flop" steering): Let go of the steering wheel while going straight ahead and the steering will immediately flop either full left or full right.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
