Re: OT calling all Ford mechanic
Posted by RockyMO on April 22, 2008 at 20:13:00 from (24.216.122.188):
In Reply to: OT calling all Ford mechanic posted by dave guest on April 22, 2008 at 19:31:30:
The MLP is the neautral switch (Manual Lever Position Switch). IF you have a code from auto zone that is the direction to go. Both MLP's and speed sensors fail so trust the computer codes outputted.
Rocky in MO
