Re: 140 hydro remote?????
Posted by Hugh MacKay on April 23, 2008 at 09:36:52 from (209.226.247.166):
In Reply to: 140 hydro remote????? posted by SamC on April 22, 2008 at 22:18:43:
Sam: After all these suggestions my personal preference is still a factory remote valve or secondly the junction block from Saginaw County Tractor. While the power beyond valve plumbed in will work, you whind up with a plumbing jungle. Some of those old C and SC tractors I remember plumbed into the system, had so many hoses you couldn'd jump off the tractor forward of the right rear wheel.
The Saginaw block is neat, port points back right along the transmission case between seat and gear shift, you can bolt the valve down behind the gear shift lever. The absence of plumbing jungles quite important on a small tractor.
