Re: Working on the 1944 H some more...
Posted by Andy Motteberg on April 23, 2008 at 19:37:29 from (4.143.217.240):
In Reply to: Re: Working on the 1944 H some more... posted by arod on April 23, 2008 at 16:01:52:
It was welded at one time, but they had trouble keeping it sealed up, so they put that gray "putty" type of stuff over it, but that did not cure the leaking very well either.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
