Gentlemen, if you read his first post, he says he removed the starter.
Dewey, if you completely removed the starter from the tractor, and that didn't help, you have a bad starter motor. It needs to be taken to a professional, and rebuilt or replaced.
Your local AutoZone or Napa should be able to test the starter for you.
Most larger towns have shops that specialize in servicing starters.
If you're mechanically inclined, you could pull the starter apart and service it yourself. Replace the starter drive, clean up the commutator, replace the brushes and bearings... None of it is terribly difficult, but you lack a way to determine if the windings are burned. If the windings are damaged, the starter is worthless.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
