Re: Furrower, hiller, shovel?
Posted by NawlensGator on April 24, 2008 at 07:48:58 from (52.129.12.50):
In Reply to: Re: Furrower, hiller, shovel? posted by Glynn Moore on April 23, 2008 at 18:10:17:
Interesting. The single discs on a single shaft that attach to the front tool bar are called 'Hillers' around here(south LA). The 'disc cultivators' however are a gang of three discs attached to a single shaft and are too big to fit on the front tool bar (the belly bar on a 140). The discs are 20, 18, or 16 inches (better to use a combination). You have to attach 2 of them to the tool bar behind the tractor. The faster you go, the higher the row.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
