Re: Two Farmall Tractors
Posted by Randy in NE on April 24, 2008 at 13:35:21 from (204.124.192.32):
In Reply to: Two Farmall Tractors posted by D. Clawson on April 24, 2008 at 13:24:27:
You can go to "Tractor Photos" over on the left side of this page in the "Galleries" section. That will help you identify your second tractor. I believe that the serial number tag is on the left seat support for the Super A. If that is missing you can look on the engine block, just below #1 spark plug (the front one), there is a small flat machined area. The engine serial number will be stamped here. Then you can go to the "Serial Numbers" to the left and look up the year.
