I assume the battery was a new one.....am wondering if the starter drive is locked up agains the flywheel on a tooth...put in 5th gear and try to rock tractor rear wheel to dislodge the starter drive from the flywheel, OR, loosen all the bolts in the starter and the drive should let go. L post on regulator should feed the light circuit, actually stands for load or lights. And, so how do you turn the ignition system on if there is no key switch? and, or, do you twist the wires together? hope this helps...ttyl, ka
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
