Re: 656F/1967/263gas/5sp/TA
Posted by ejr-IA on April 24, 2008 at 19:24:53 from (204.11.182.58):
In Reply to: 656F/1967/263gas/5sp/TA posted by Jerry Gilliam on April 24, 2008 at 16:07:12:
Dont for get to put a rubber band around the barrel roller bearing in the rear housing before you slip the TA housing in to the rear end.And dont forget the Oring on the hydraulic suction line between housings.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
