Re: piston ring
Posted by Janicholson on April 25, 2008 at 08:35:06 from (199.17.6.122):
In Reply to: piston ring posted by sullyoo1 on April 25, 2008 at 03:56:51:
Diesel engines are subject to dramatically higher compression than gas engines, and the ring technology still alows some compression bypass, and deposits in diesels. Ring structure and plating methods were improved in the mid century years, and the reduced drag of the lower ring was considered to be important enough to eliminate them on the gas engines. The ring is often called a scraper ring and contributes to oil control, and deposit buildup. Thus all rings should be installed on diesel engines. JimN
