Farmall Tractors Discussion Board
Re: Farmall H Upper Bolster......Again
Posted by Todd Markle on December 17, 1998 at 19:46:44:
In Reply to: Farmall H Upper Bolster......Again posted by Jim T. on December 15, 1998 at 05:41:23:
A little heat might help.The trick is to heat the
gear without getting much heat in the shaft. Heat it quick with a big tip in your torch. If you can heat the gear quickly before the heat transfers to the shaft, the gear will expand faster than the shaft and should help it come loose. Dont get
it too hot that it softens the gear. How do you plan to install the bushings? I have never put bushings in but when I put a seal in recently, I had to make a driver for it. I suspect you will need something like a cam bearing installer/bushing driver.
Post a Followup
: Re: Re: Farmall H Upper Bolster......Again
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
