Posted by Athol Carr on April 25, 2008 at 22:02:43 from (122.57.100.124):
In Reply to: F series Experts posted by James Williams on April 25, 2008 at 15:10:04:
The 7 mph F-12, F14 used the same 3rd gear as the O-12, I-12 and Fairway-12. There was also an option to use as high speed ratio between gearbox and differential which would give about 9.5 mph. This later gearbox to differential ratio was used in the O-12 etc. which had a road speed of 10.6 mph. However, 1st gear was over 3 mph at 2000 2pm.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
