Re: 200 fan
Posted by Andy Motteberg on April 26, 2008 at 18:57:25 from (4.143.220.66):
In Reply to: 200 fan posted by Don Anderson on April 26, 2008 at 17:01:35:
Are you sure you have the correct size belt? Did you put the belt on tight enough? New belts need to be re-tensioned after being run for 5-10 minutes.
