Re: 856 Axle housing and Brakes....
Posted by IaGary on April 27, 2008 at 08:13:19 from (67.55.192.138):
In Reply to: 856 Axle housing and Brakes.... posted by Dan Swanson on April 27, 2008 at 07:49:08:
One thing you might check on the brakes.
There is a slot at the bottom of the drum that needs to be kept open to allow brake dust to fall out.
If you get a build up of brake dust it can cause the chatter.
Gary
