Re: Farmall 504 Oil Leak in Axle Housing
Posted by LaVern Skarzenski on April 27, 2008 at 11:34:05 from (66.211.228.241):
In Reply to: Re: Farmall 504 Oil Leak in Axle Housing posted by TractormanNC on April 27, 2008 at 11:20:36:
Boy that was quick. Thanks a bunch, Sounds like it shouldn't be too bad of a job.
Next question, Once I get the wheel off from the axle and the exposed axle cleaned up, is it a matter of just removing the housing bolts and pulling or prying the housing off of the axle? Or do I need to do something the to outer end of the axle housing with the seals and bearing? Thanks.
LaVern
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
