Re: Snapping back H throttle
Posted by JT on April 27, 2008 at 14:46:35 from (68.25.140.28):
In Reply to: Snapping back H throttle posted by Mike CA on April 27, 2008 at 08:23:17:
Make sure the teeth in your throttle are not worn out, also. mine was doing same thing, took off, refiled notches in dome, welded and filed the tooth on the handle, then did as Rusty Farmall suggested adjust fulcrum under hood about 2 turns, and no more problem.
Jim
