Axle housing seal replacement
Posted by Carden on April 27, 2008 at 18:03:50 from (74.33.241.19):
I"m sure I need to remove the 3 point but can I replace the axle housing seal (transmission side) without pulling the wheels. I have read that some have loosened the bolts, cleaned out the seal and used the blue RTV to seal it back up. I"m wondering if I jack up the center of the tractor itself leaving the wheels on the ground just enough to hold them can I separate it enough to fix the leak?
Thanks
