Re: F-20 Pulling!?
Posted by garytomaszewski on April 27, 2008 at 18:37:42 from (4.158.174.9):
In Reply to: F-20 Pulling!? posted by linemanfarmer on April 27, 2008 at 17:46:18:
Really a nice looking 20. Did you overhaul with the bigger(4") pistons? Was the head planed any you can take off alot to give higher compression? For a little more HP add some model airplane fuel to hi-octane gas, advance the timing one hole on the coupler, fill the air cleaner cup with isopropyl alcohol,AND get rid of the muffler (see the burned spot = backpressure). Open the load screw until you see a LITTLE black smoke at wide open throttle. With the spoke wheels you should be able to add weight to the front end. They were not a high RPM engine 1200-1400 I think, but I believe all the adjustments were in the linkages. Lower the drawbar to 18-20 inches and have fun.
