if you pull the plugs out of the axel tubes on the bottom and drive it around it will drain the whole system. It is common practice to run the older IH rears over-full on oil when doing PTO work in the hills to keep the oil level high enough so you don't take the PTO out. this will also over fill the axel tube,as I recall their is a 1 1/2 inch hole for the oil to drain back into the rear and a 1X2 hole from the rear to the trans.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
