Re: M FARMALL
Posted by Owen Aaland on April 28, 2008 at 02:05:34 from (65.165.246.73):
In Reply to: M FARMALL posted by DANETOWN FARMER on April 27, 2008 at 15:09:36:
DANETOWN FARMER said: (quoted from post at 15:09:36 04/27/08) Have a M FARMALL that wants to jump out of 5th gear. What is the fix for this problem?
Usually this is caused by a bad pilot bearing on the front of the mainshaft. It rides inside the input shaft and when the bearing gets worn it no longer holds the mainshaft and input shaft in alignment allowing the fifth gear spline to walk apart under a little load. If the bearing is good the splines can be quite poor on both the input shaft and fifth gear and still not cause a problem.
