Re: 140 steering
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by JLE on March 09, 2000 at 12:51:08 from (166.72.112.9):
In Reply to: 140 steering posted by Kip on March 08, 2000 at 16:59:35:
The last two I had apart, I found some play between the sector and the vertical shaft, one just replaced 1/2 moon key, the other one key way was worn and had keyways enlarged to next size larger key. Tightened both up .
Post A Followup
: Re: Re: 140 steering
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
