Posted by Bob M on April 28, 2008 at 11:07:18 from (151.190.254.108):
In Reply to: Farmall H weak start posted by Wisconsin_Joe on April 28, 2008 at 10:20:06:
Sounds like a tired starter. However it could also be a failing starter switch, a weak battery or possibly a faulty terminal crimp on one of the new cables (it CAN happen…)
Also if the grounded battery cable is not clamped under a bolt that’s directly into the transmission or clutch housing (ie it’s bolted to the battery box sheetmetal) relocate it.
You might try this: With the ignition switch off, crank the engine for 5 – 10 seconds. Then quickly feel the starter switch and each cable terminal. If any are hot to the touch you’ve found the problem.
If all the above check out, time to pull the starter for a peek inside. Most likely the brushes are worn, commutator is dirty, bearings are dry, etc. A trip to your local starter/alternator shop is then in order.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
