Re: Super A clutch adjustment
Posted by ScottyHOMEy on April 28, 2008 at 17:15:29 from (70.105.254.22):
In Reply to: Re: Super A clutch adjustment posted by P and R Pete on April 28, 2008 at 16:49:50:
Good job, Pete! I never gave a thought to the hole in the side.
Mike, the hole on the side of the bell that you've been looking through is so you can get a grease gun into the zerk on your throwout bearing. Down below that, on the bottom and a little forward, is an oval shaped hole that may have a cover over it with a threaded end sticking out held by a wingnut or regular nut. That is the forward hole I was talking about.
The hole Pete has the picture of, and the hole you want for adjusting your freeplay is on the underside of the torque tube at the very rear, and doesn't have a cover.
