Re: Preparation for painting of a rusty surface
Posted by CNKS on April 28, 2008 at 17:27:21 from (216.144.104.128):
In Reply to: Preparation for painting of a rusty surface posted by LenNH on April 28, 2008 at 14:12:09:
A quick way is to use a wire wheel on an electric drill, then use Must For Rust from Home Depot. It does not have to be washed off, but you can remove most of the residue with a scotchbrite pad, then use wax and grease remover, resulting in a clean surface. But I prefer sandblasting for heavier steel like you have. Then use the Must For Rust to prevent rusting if you aren't going to paint them right away; keep them dry. Skip that if you are painting soon after. That is the quick way. The pits will be visible through the paint, the paint will actually highlight them. You really should fill the pits with body filler (that is a generic name, there are many similar products) sand smooth, use epoxy primer, then a sandable surfacer. A lot more work, but the pits will be invisible.
