Re: Correct way to adjust a pressure plate.
Posted by MN Scott on April 28, 2008 at 18:04:16 from (206.9.216.38):
In Reply to: Correct way to adjust a pressure plate. posted by MAGMAN on April 28, 2008 at 17:23:02:
You got that plate from A&I right? It should be all set up and the bolts sealed from the remanufatuer. I haven't seen a reman tracter clutch that has needed adjusting for 20 years.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
