Re: torque spec,s
Posted by nebraska kirk on April 28, 2008 at 18:29:11 from (98.19.45.93):
In Reply to: torque spec,s posted by Axe24 on April 28, 2008 at 15:28:35:
Torque head bolts to 70 ft/lbs.
Sequence for tightening nuts should begin at the center of the head and then back and forth across the head toward each end.
Also, torque the bolts in 3 or 4 steps. I always start at 1/4 torque, torque all the bolts, then torque again at 1/2 torque, then 3/4 and finally full torque. Torque again when engine is hot.
