Re: isopropyl alcohol in Aircleaner
Posted by the Unforgiven on April 28, 2008 at 19:25:50 from (66.146.249.116):
In Reply to: isopropyl alcohol in Aircleaner posted by linemanfarmer on April 28, 2008 at 19:20:22:
I would think the alcohol in the air cleaner would be a complete waste of time. And you will gain zero advantage in high test fuel unless you raise the compression ratio enough that you can't run pump gas.
