Re: isopropyl alcohol in Aircleaner
Posted by Janicholson on April 29, 2008 at 06:09:23 from (199.17.6.122):
In Reply to: isopropyl alcohol in Aircleaner posted by linemanfarmer on April 28, 2008 at 19:20:22:
Alcohol in the Cleaner just richens the mix with a mediocre fuel (~65% of what gasoline has per unit volume) and unless less fuel is allowed through the carb, it will be rich, and less power will be produced. NAH don't do it. It can also promote explosive decomposition of the aircleaner.
The use of the lowest octane fuel that will prevent spatk knock (cheap pump regular) in a tractor with stock compression is the most powerful. If the compression is above 175 psi, then single steps above regular should be tried to lower knock. The high octane fuels burn slower, and have higher ignition temperatures, not more intrinsic energy. JimN
