Re: isopropyl alcohol in Aircleaner
Posted by garytomaszewski on April 29, 2008 at 06:48:42 from (4.158.174.248):
In Reply to: isopropyl alcohol in Aircleaner posted by linemanfarmer on April 28, 2008 at 19:20:22:
I was the original answer poster. Every answer here is correct. Alcohol filters as well as water, not for long term use just the pull, it cools the air (dense air enables richen fuel). All the suggestions were to use combined, advance timing=higher octane fuel to prevent spark knock. Model air plane fuel used to be alot like nitro-methane very explosive, then mix with av-gas
